A
Anonymous Posted on Jun 13, 2014
I am getting error code c-3102 on my Konica minolta bizhub 6500. How can I fix this?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 25, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910520
Points
11959
Fusing unit motor or release senor will require a technician to fix.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • Posted on Nov 19, 2007
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 25, 2009
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
Anonymous
  • 6 Answers
  • Posted on Apr 09, 2010
SOURCE: how to fix error c0f32
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
I have a problem with my konica minolta bizhub c451 giving error Code C 3102
c3102 for Fuser Unit abnormality.
Check Fixing Unit and its Gears , also the drive gear on body.
Reset by Switch On Holding Utility/counter Button for 10 seconds.
Touch TROUBLSHOOT and restart by Power off and on
Konica minolta bizhub c 7000 error code c 2221 how to fix?
Any one of the following might cause that code,
AC drive board (ACDB)
• Printer control board
(PRCB)
• 1st transfer pressure
release motor (M19)
• 1st transfer HP sensor
(PS15
1helpful
How can i do for error C6702
http://www.copytechnet.com/forums/konica-minolta/30879-konica-minolta-biz500-code-error-c-6702-a.html
guy does eventualy fix it on later pages
worth a good read
i got board half way down
a good tip with rollers {rubber not sponge} is too use white vinegar wipe it on leave it to dry
and run few some fully black sheets...prints
then it works magic
Reset error code 3102 on Konica Minolta bizhub 6500
drive issue for the fusing motor, get a technician to look at it
How do i correct konica minolta 6500 error code 3102
have tech come out to resolve this not easy fusing motor issue and or sensor or both
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
