sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Your defrost timer is probably staying on too long, or the defrost thermostat is not sensing that the temperature was that high. It does tell you that the defrost heater is operational, just that it is staying on too long.
Not really. UCR means under counter refrig. It could freeze some products, like lettuce, but the unit will not function for long periods of time as there is not defrost cycle and it will freeze up.
Check the defrosting coils. They may have finally gave up the ghost. You will have to take some covers off to get to them and I can't tell you how to do that so trial and error is your choice or a service man call. Hope this cures it though. remember my thumbs up for the effort, The Raz Shack
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
