If you tried with other cd inserted then still doesn't read, the cause is either the optic lens dirty or the spindle motor doesn't rotate. tried to clean first the lens using a cd lens cleaner , if no available you can do the manual cleaning but this time you will need to remove the cover of the dvd player to access the lens. you can use a cotton buds with alcohol. clean the lens be careful not to damage gently apply not too force when cleaning the lens.
Mine says the same. Is that an issue? It works and plays music
It should not say "goodbye". So, by "hello", it is saying that it is "waking-up".
