You remove the PRINT HEAD????? DID YOU FOLLOW THE Service manual????????? Well you caused your own problem now you need to do a alignment. of the colors. you also might check the ribbon cable you removed and all the connectors you played with and check each one is secured. Recommend you don't ever remove the print head which houses the LASER unless you follow the service manual. Well you need to get to service mode and run registration procedures. try this site for a service manual or better yey have tech come out and run the required checks.
sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it
Sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it, unless you know what your doing
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1 will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again. To leave the mode press stop then 9 then 9.
