EA - Electronic Arts Need For Speed: Carbon Logo
R
Rana Mateen Ali Khan Posted on Jun 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do stop working need for speed carbon on window 7
Jerry King
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 187 Answers
  • Posted on Jun 13, 2014
Jerry King
Expert
Level 2:
New Friend:
Cheetah:
Answers
187
Questions
0
Helped
44710
Points
493
Did it work previously? If so, uninstall and re install the program.
If not, check for compatibility with your PC.
2helpful
Stalling
.... Robert Grove
johnallen496, when you say it stalls at low speeds and stops, do you mean when slowing down and coming to a stop? does it stall at low speeds while the car is moving with your foot on the pedal just a little like when driving through a parking lot?...
I used the wrong box above, oh well ....
The most common cause of stalling at low speeds, especially idling and decelerating to a stop is carbon buildup. The throttle plates get coated with carbon closing down the opening slightly, this affects the idle speed, causing the engine to stall at idle and coming to a stop.
also carbon builds up in the cylinders and absorbs fuel intended to be burnt, leaning out the mixture and causing rough/low idle and stalling - especially when the engine is cold. Dirty injectors can cause the same symptoms/results
As a maintenance routine It's good to have the throttle plates cleaned and perform a top engine de-carbon treatment, and fuel injection service in more severe cases
Sea Foam makes a spray that works great for minor de-carbon service, just spay it into the throttle plates while it is running, one to two cans will do, add a can of Sea Foam or Techron to the gas tank each time you fill up for the next few tank full's.
If you still have problems sek out a qualified professional
Robert Grove, WEGO2U Mobile Mechanics
Orange County Mobile Mechanic Orange County Mobile Mechanics 714 709 4594
2helpful
I forgot the code for need for speed carbon
Need For Speed carbonFHXX-Y5J5-J1J1-31S5-1911
VJC4-FRJT-P0H4-X6R5-1911
EA22-AHDG-G8F6-64R4-19113
WBB-HGFK-4CCH-C5MD-XEXW
QEFP-MA2W-MNL8-DKES-KY2C
TWSA-5699-LZVM-KQS2-F9EL
DPQY-KFG5-GBQ9-9T27-QQGD
NFSU2, NFS carbon and NFS most wanted - Keyboard not functioning correctly
LOL, probably a Windows 7 conflict if you just upgraded. It has tones of problems just like it's predecessor Windows Vista.
Need for speed most wanted has stopped working??
you can try re installing the game , if the same problem persist, check the OPERATING SYSTEM compatibility of the game... if its not compatible with windows 7 it wont work normally, try to find NFSMW that is windows 7 compatible here www.isohunt.com
Is the rio carbon disc compatible for windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_51.jpg
10helpful
2answers
NFSC.exe has stopped working
I'm sorry perhaps I am misunderstanding. You are using a Need for Speed Carbon copy for playstation, on a PC ?
NFSC.exe is a windows error. Are you using the playstation disc in a computer ?
Need for speed carbon not running
your need for speed has some virus files which effect the system 32 files of ur window so install it again or bring the new version of need for speed
I have hp dv6 1110ax .
Try vista SP2 as the same problem occured to me and was solved by updating to windows vista SP2 alternatively you can also try with Windows XP sp3
NFSC crash
that is the same thing that happened to me. if your computer is already vista it will stop working because vista is slow on games for windows xp.
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
