If you buy another graphics card and it has this feature, you can do it.
Disable the old on board graphics card first.
Look for the appropriate VESA, PCI, or PCI-Express interface in your manual available online,and make sure the new graphics card works with your motherboard.
Hi, For attachments you can double click on them you will get a prompt to save the file select the location to your document and click on save save. That will save all the attachments.
First of all install its software then your PC recommend to attach the cam, so you should attach the cam. After attach the cam it will automatically check its driver. Your A4tech CD should be in CD Rom. Now in a minute your installation will be complete.
Thank You
First off this will occur if you are trying to trasmit over a Modem, which has a very very slow Connection. Also if this is a large email, and this is a company PC, they will most likely have a disk quota for your email. So, try to transmit a smaller attach. and see if you get the same results...
with a cam connected to ur pc and quick time installed you open the program and record when done save your file to folder .in email type your message then click add attachment or attach and a search folder comes up to locate where the file you want to attach is located.locate the file and click ok ...click attach and email will load file when loaded send mail...done
What can & cannot be downloaded will be determined by your setup in ActiveSynch on the desktop.
When connected right click on the Inbox on ActiveSynch main screen & select settings. Check mark the "Include File Attachments".
If you are downloading the jpg files uncheck the "Limit Attachment size to" so complete attachments will be downloaded.
On the PDA start the inbox, tap on Tools - Options - Storage. You should get the option of saving the attachments on storage card if one is available to save on main memory usage.
But this might not be an option if you use a CF wireless ethernet card for connecting & Synching. If it does show up you will have to uncheck this option to save the attachments in main memory.
Hope this helps.
