WX416 CONSUMER CELLULAR FLIP PHONE I HAVE PUT IN MY PASS CODE BUT IT SEEMS THAT EVEVY TIME I TRY TO CALL VOICEMAIL IT TELLS ME THAT I CANT COMPLETE THAT CALL
SOURCE: setting up my voicemail on my Motorola C139 TracFone
Elementary, just as you would in any other phone, just dial your number, and the phone will talk you through on setting up your voicemail.
SOURCE: unlock code for free
COngratz everyone!!bcuz i found how to unlock the unlock code
Easy do you remember the security code for ur mobile
if u remember
it than i 100% can help u solve the problem!!!u just press message and
it want u take the unlock code!! than u press the menu button and it
change to insert the security code than u can get in!!!! (default
security code:0000 or 00000)
SOURCE: Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
SOURCE: I cant seem to set up my voicemail.
You will need to contact your service provider to have the voicemail retrieval number programmed into your phone. They can also reset the voicemail feature since it has not been set up yet.
SOURCE: Problems setting up Net10 Voicemail
If you are getting the "voicemail does not exist message" this means that the voicemail feature is not on your account. Unfortunately you will have to contact your service provider and ask them to add the voicemail feature back onto you account. Have them test and make sure that you can access the voicemail before they end the call to ensure they have fixed the problem. Hope this helped.
