It does every thing else , but will not spin
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
