SOURCE: i have a lg fridge/freezer and water flows from
You have a blocked drain hole at the bottom of the fridge put very warm water in the the drawers and remove once they un thaw then remove them and clean the drain hole in the bottom. If you need more help just post here and I will give you more informaion, also if it's got a lot of water you will have to remove the drip pan and drain it out
SOURCE: ice maker leaks and ice
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box as to where the water is coming out, in front of the fridge or the rear? Is there any ice buildup under the freezer drawer, have you checked the condenser coils to see if they are dirty/clogged with hair (common problem if you have any pets at all).
