I need to lubricate the walking belt.
SOURCE: treadmill powers up but belt will not rotate
Check to see if the motor is spinning. If not spinning, then use a voltmeter to find out the voltage of power going to the motor that spins the belt. See if you can rotate it by hand.
SOURCE: I purchased a used Epic
Dear Sir: o 1 Check that the surge protector meets the specifications listed in the manual. o 2 Remove the key from the console. o 3 Unplug the power cord. o 4 Turn rear roller bolts 1/4 turn counterclockwise using an Allen wrench. o 5 Keeping the walking belt centered, you should be able to lift each edge of the belt 2 to 3 inches. o 6 Plug the power cord back into the surge protector. o 7 Reinsert the key into the console. o 8 Repeat the process if, after the treadmill has run a few minutes, the walking belt is not properly tightened. o 1 Remove the console key. o 2 Unplug the power cord. o 3 Follow the same steps used for a slow walking belt.
Hello, I hope is everything is o.k
I will try to help you.You must be patience and carefully, and use basic tools+Dvom.
See the videos with common sense:
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?v=HmVt-SHSYAI&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
1. Slow Walking Belt
2. Walking Belt Slips
With all this information you will fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: The belt on the Epic
I will try to help you:
See the videos:
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
With this you will fix it.
E.CUADRA
