1 Apply the parking brake.
3 Remove the fuel pump relay from the power distribution center under the hood. Look at the underside of the power distribution cover, and locate the fuel pump relay.
7 Lift the fuel tank into position, using the jack.
8 Attach the fuel filler hose and vapor return hose to the fuel tank.Tighten the clamps with a Phillips screwdriver.
9 Pivot the fuel tank retaining straps into position. Tighten the fuel tank retaining strap nuts with a socket and ratchet. Lower the jack.
I've found them and can get to the front of the strap. How do you get to the rear bracket; by taking the rear bumper off?
