Select Jazzy Used Electric Wheelchair Logo
A
Anonymous Posted on Jun 12, 2014
Does jazzy have to be in certain position to charge it
Scooter Doctor
Level 3:
Master:
  • Select Master 401 Answers
  • Posted on Apr 30, 2016
Scooter Doctor
Select Master
Level 3:
Master:
Answers
401
Questions
0
Helped
122556
Points
1542
I tell my customers to charge the chair with the joystick on! otherwise it should be upright in a drive position do not charge a chair upside down! I don't know why someone would do that but...
once the charger is plugged in the chair is inhibited from driving, so if it is plugged in it won't drive.
Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
2010 Jazzy Select 6 ultra, VR2 control unit. I know they can be slowed down for inside. How do I get the factory speed of 4 mph back?
You need to have a hand held programmer that techs use or even customers. This programmer plugs into the charging socket under the joystick, turn unit on then change speed profile back to 100%. They are set back to prevent accidents for certain patients. Get online and look up Pride Mobility to buy one or have a local dealer send a tech to your location. Good Luck.
My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
Battery charger not working
how long in storage? if the voltage is below a certain threshold the charger wont come on for safety reasons. try removing and charging each batt separately careful to note the EXACT!!!!!!! positions and configuration when putting them back then try charger if not then batts are prob bad
Batt.in my elect. wheel chair will not start charge
how dead are the batteries. some chargers won"t charge until a certain voltage threshold is met as a safety measure
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
My jazzy chair did charge up when we plugged it in last night. Is there something else wwe can do to get it to charge up?
Things I would check are ... Power at the outlet? Is the charger ON? Is there a fuse or circuit breaker involved? Are you certain it was plugged in (charger to charge port)? Have you noticed any deterioration in its operation recently?
1helpful
Top Select Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
