SOURCE: Panasonic PV-DV100 Mini DV...
Try to find same battery charger or camera and do Cross-Check, hook new charger with camera and confirm charging process and hook your charger in other same camera and confirm is it working? You will rectify the problem unit, either camera or charger.
SOURCE: "wrong format" error panasonic pv gs9
You really need a panasonic camcorder or need a new camcorder that can read your mini dv tape. good luck
SOURCE: how to transfer the video file from my mini dv
Hi!
Are you using Windows Vista or XP? Have you downloaded the correct driver and installed it on your computer?
Also, the most easiest way on how you can copy the video file from your camcorder is by taking out the SD card and then plug it in your SD card reader. It should be detected as a mass storage device.
SOURCE: My windows 7 laptop does not recognize my
You are going to have to check that your firewire is being seen by windows 7 first of all. If not you will need to rectify that.
When you do get it to recognize it, here is a link for an update to the program that came with your camcorder for it to work with Windows Vista but it should also work for Windows 7.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Hope this helps,
