Question about Whirlpool Inglis IP8200 Dryer
It takes 3 or 4 drying cycles to dry the clothes.what is wrong?
6ya staff
SOURCE:
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Posted on Feb 11, 2009
Anonymous
SOURCE: Dryer takes too long to dry my clothes
The first thing to check is the temperature. start the dryer, and check it about 10-15 minutes in, is it very hot or kinda cool? IF its very hot, Look at the lint trap channel to see if there is a build up of lint, then remove the vent hose from the back of the dryer and make sure it has no lint in it and that it is clear all the way through the outside of your house. Make sure the flapper for the dryer on the outside is clear.
If it feels coolish, you will need to replace the heating elements, or a control circuit. Neither are expensive.
IF you do it yourself it could cost maybe $50-100. Since your asking for help here, I urge you to pay for a professional to repair the dryer which may run $150-200. You will have to decide if repairing the dryer is worth the investment.
Posted on May 10, 2009
livetech
  • 583 Answers
SOURCE: Our dryer takes multiple cycles to get clothes dry
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Posted on Jun 12, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: The clothes take forever to
Posted on Nov 23, 2010
ron7493
SOURCE: Dryer heats up but clothes won't dry
I have an amana electric dryer. Changed out thermal fuse and cleaned out vent. Thermal fuse is blown again, but I noticed that it is not cycling. The dryer is very hot on the outside on top.
Posted on Sep 11, 2011
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My dryer is slowly - over the course of about 2 years - taking longer and longer to dry my clothes. I usually have to run the clothes through 2 or 3 drying cycles to get them dry. What do you think is...
Usually this is caused by the heating element (s) going out.
Tear the dryer down to the elements and test for continuity through them. If one fails the continuity test, replace it.
Best regards, --W/D--
Jan 21, 2011 | Dryers
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
