the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sorry to said but Jamo SW410E is an active subwoofer. This means that is has his own amplifier for the speaker (that why you can see at the back panel of the sub the RCA connectors for Left and Right (line in level):
In the meantime your Panasonic SA-PM19 stereo system has none connector for audio out (except the one for the heaphones). So it's not possible to connect these 2 audio devices together.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards Please kindly rate this solution Stelios direct FixYa link: http://www.fixya.com/users/technical114
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
This speaker system is described as consisting of "passive" satellite speakers with an "active" subwoofer. Passive means they require an external amplifier to work - and conversely active means there is a built in amplifier. To "power cycle the board" simply disconnect the power cord for a couple minutes (allows capacitors in the circuit to discharge) and plug back in. That's it.
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel
sound from just one speaker. Simply hook up both the left and the right
channels to the special terminals on the speaker. Hook up one channel
only, if the speaker is to be used in a conventional stereo set-up. I found this on jamo site hope that will help you
