Question about Nortel Networks Norstar T7316 Business Telephone nt8b27aaba Charcoal
Set up nortel t316 with gn9350
Can I set this up with a gn9350? I've tried following the manual, but it's an older phone, so can I set up Bluetooth with it? how?
My bluetooth is paired to my Pantech P6020 but it won't automatically connect.
Unfortunately there are different versions of bluetooth. Pending on the age of the handset.
You could try a bluetooth adaptor
Dec 28, 2017 | Cell Phones
I can not get the headset to turn on.
If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
Jan 27, 2018 | Jabra BT160 Wireless Headset
Nokia 6303 classic camera and bluetooth not working
Hi.Follow this link nokia 6303 camera and bluetooth solution - Google Search and select the first image.I've solved this problem by following this particular image.I gave you the link because I don't have the image.The problem cause from the lost/damage of BSI line.Good luck
Apr 01, 2012 | Nokia 6303 Classic Tri-Band Cell Phone
My bluetooth doesn't switch on
nokia 3310 does not provide bluetooth
Mar 01, 2012 | Nokia 3310 Cellular Phone
Following directions for plantronics 240 and for samsung dart to pair, the phone scans but has found other phones in the bldg. I've tried most recently and the picker list comes up with nothing -- no...
I would suggest taking the battery out of the phone for a few moments, then try pairing the headset and phone again at a location where there are no other Bluetooth devices in range for your phone to pick up on.
Good luck from Headsets Direct!
Jul 06, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Rejects my Samsung Galaxy
Try to reset all the settings you've done, on your phone and on the speaker.
If you've done this, you could try to do the whole part of connecting your devices again and it should work!
Mar 26, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
MOBILE PHONE NOKIA
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Nortel Networks Norstar T7316 Business Telephone nt8b27aaba Charcoal Logo
47 people viewed this question
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
Harrie
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
