? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
All symptoms show that cable box is cause of problem, not sure that its internale circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
TV sounds good because it works fine with blu ray player that is HD signal as well.
Change cable box just to confirm it.
I hope this tv would be under warranty so ask nearest Sony service to update its firmware under warranty cover that might fix the issue.
Thanks.
Vertical out transistors bad solder, or return linearity capacitor bad (a large capacitor, usually between 1000uf and 2200uf.) They're near where yellow and brown wires from picture tube connect to main board. They are larger transistors.
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Convergence amp ic bad http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html Sony Convergence http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/ http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
The Sony "S" series is not HD compatible in any way. To see an HD program you would require an HD down-conversion box. This would make the pictures look like regular TV, but may have some distortions because of the 16:9 scan ratio from the HD programs, unless you model series is 16:9 compatible.
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
