Camera worked fine. now when i turn it on, i get the canon screen, then i hear a few beeps, screen goes blank and i see text "lens error, restart camera" and then the camera shuts off
SOURCE: Lens Error
I had the same problem and fortunately for me it was simple to fix. I gave it a little push & twist on the lens and to my surprise the lens retracted and now the camera works fine. Good Luck!
SOURCE: A460 lens error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: cannon sd880
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
SOURCE: len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
SOURCE: Canon PowerShot SX 100 IS lens error
