Dometic Rooftop RV Air Conditioner Logo
A
Anonymous Posted on Jun 12, 2014
I'm having a problem with a digital t-stat
The control box in the ac unit will not run the furnace
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Jun 13, 2014
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229584
Points
3082
Digital Thermostats... good idea on paper, but in practical use they are less than desired. Get an inexpensive mechanical thermostat, wire it in, and run the unit. When you reach your comfort zone adjust the temperature on the unit so it just shuts off, and LEAVE IT ALONE.
heating and cooling are more than just making the air the right temperature, EVERYTHING in the space needs to reach the desired temperature, walls floor, furnishings....everything. And while it is true that a digital thermostat can save you a few cents per hour in operating costs, the time you spend to learn how a particular high tech device works, experimenting with the programming, possibly battery back-up power to maintain a program, the hassle is just not worth the savings, particularly in an RV where you spend limited time anyway.
wiring a standard thermostat is green for fan control, red for power in, white for heat, and yellow for cool. You can test your unit's function by connecting red green and white wires to check for heat, red green and yellow wires to check for cool.
If these tests fail, most likely you have a bad component on your control circuit board and it should be replaced. If you have experience with circuit diagnosis and repair you could save a buck by replacing the bad part of the board, but most folks will save time and money simply swapping out the entire board.
If the tests for function pass, then wire in your new, simple, easy to operate $20 thermostat and call it a win.
Raymond Lamont
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jun 12, 2014
Raymond Lamont
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
2295
Points
16
It may be a wiring problem at the thermostat, quite often there is a jumper missing in the thermostat between the R terminal and the RC terminal. hope this helps
2 Related Answers
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Aug 14, 2008
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Anonymous
  • 68 Answers
  • Posted on Mar 19, 2009
SOURCE: ATWOOD MOBILE FURNACE RUNS WHEN IT WANTS/
Check your furnace for power. will be 4 wires. power ground and 2 thermostat wires. Check for power at the time delay relay, if you have power there check for power going in the fan motor, if power in motor wire, motor is bad. If no power in motor wire and power going to circuit board take the 2 thermostat wire apart and wrap the 2 together comimg from the thermostat. Fan will stat in about 30 seconds. If it does you need a control kit in the ac. But sounds to me like you have a furnace problem.
2answers
T-stat is not getting 12v-not to furnace or AC.checked all breakers all connectors. I did connect the battery directly to the thermostat system and everything worked.
i don't know. please turn on 110 volt switches to furnace and air conditioner. set thermostat at reasonable settings for both units. my furnace has a separate switch on the furnace that isolates my thermostat. you may have one. also, my thermostat does not have a clock. if yours does, there may be a small extra battery for the clock.
I have a duo therm ac unit on 2003 gbm f53 fan only works in the on position not in the auto also unit will not shut at stat only with breaker any clue
First you may check the t-stat settings if its a digital tstat. Some t-stats need to be "set up" for your unit. The configuration of the t stat may be for a gas furnace (which controls its own blower) and you may need it to be configured for an electric (heat&cool) unit which the t-stat controls the blower operation. As for the non stop operation that could be a normally open switching relay that is stuck closed. Or numerous other situations. Can't help much there.
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Power up unit and thermostat, circuit board and gas valve smokes. checked transformer and its output is 24vac. this happened after a thunderstorm. blower works manually from furnace but not @ thermostat....
You have a short circuit, which is obviously dangerous. Your blower motor is controlled via a 24VAC control circuit, but is 120VAC. The circuit board and gas valve are probably history, but it needs to be troubleshot to determine the scope of the damage.If you remove T stat you will see several colored wires. The red and green wire when touched together should cause your fan blower to run. If that works when you bypass t stat the t stat is gone. The red to white will open your gas valve on your heater. The red to the yellow or blue will start your AC compressor or condenser fan motor. Be careful with the yellow and blue wires as one is actually a neutral and one goes to the AC contractor on your condenser unit contractor. Hope this helps!
1helpful
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
2answers
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
1helpful
FURNACE OR AC WONT TURN ON
to see if it is the t-stat or the system you can unwire the entire t-stat and jump out the wires. never touch the blue to any other wire or you will blow the low voltage fuse on new board. if you jump red to yellow and your condensing unit cycles on the t-stat is wired wrong or wrong style. If not go check the yellow wire at cond. unit and see if power is even going to it.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
