SOURCE: WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
SOURCE: my wd640 trips after a second of pressing start,
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the dryer ID doesn't mean very
much to me. Over the years, I haven't had much
trouble with my dryers. However I can refer you to
www.applianceaid.com where they have very good
trouble shooting and repair information on dryers and
other appliances. I think you'll find what you need
there. If you have an error code you can probably
find the meaning of it there. Good luck with it.
If I have helped you, please rate my advice on fixya.
SOURCE: Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
