Control panel getting really hot to touch and can't turn off or cancel
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
control panel light all of a sudden do not come on and my unit wont start model kud101fl
SOURCE: control panel cancel light blinking as well as
where do i connect the upper rack water conduit tube for the kitchenaid dishwasher
SOURCE: blinking lights, not washing
Usually blinking lights are indicating bad touch panel buttons. Remove kick plate, (black panel under door) and find service instructions there. It will tell you how to test button panel, as well as any codes flashing. Also will tell you hot to try a reset.
SOURCE: The control panel start/resume button is NOT
Sounds like you may need to replace the user interface (control panel)
