Common problem with vw bora, i have a v5 model and my reverse lights didnt work! if you look in at the top of the gearbox you'll see a plug with a wire going into it. check the wire for a break , just join the wires together again ,make sure you join the same colours to each of them and its job done.
Hi their how are you ? are you local to east sussex ?i work out of their it hard to say why your airbag light i on most of the time it the wireing undre the front seats get move or comes unpluged but you wont be able to turn the light out without a computer if its loged a fault now as it thinks that there is something wrong it would have to be rest sorry. the abs light comeing on when you start the car means their is a fault with the abs motor or a wheel sensor but again with out pluging in to the car its hard to tell you what the problem might be the reverse light is most of the time ie a bulb switch in the gear box or a fuse . i hope that helps you let me know what happens thanks
