Displays DV-D2 when original remote from older unit opperated. And will not opperate any functions
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
SOURCE: remote not working
Your remote can control two different machines.Check the owner´s manual and find how to set it for DVD D1. Taking the batteries out of the remote for at least an hour might do the trick.
SOURCE: actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
