Thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
SOURCE: I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
