I also have bought a Sony handi cam, cannot retrieve management information. message continually appears when I connect to the computer. It is not usb connect. I have checked both sides the HDD and the Memory stick. I have updated drivers , still no luck. Is there a patch to fix this? Thanks
Then the video data files are larger than 100 GB, simple as that. Video uses a lot of GB's, so that doesn't surprise me one bit. 100GB is a tiny amount of storage compared to modern machines, mine has 500 GB's, my Desktop has 1 TB.
You can use a card reader to transfer your file from your handycam to your computer. Remove the memory card in your camera and insert it to the card reader and insert it to your computer to transfer your recorded video.
When you turn on your connected Handycam, you are prompted to select a connection from the touch screen. Make sure you select the USB-HDD connection, and not the flash memory.
Try burning the Video to the Window Movie maker and finish the File as a High Resolution FILE AND THEN try burning the final movie file to the DVD A little long but should work i think
Took me a lot of cursing, and it's very simple. On your camera's screen there are 2 options saying "USB Connect". Only when you look really closely do you see that the 1st one is for the hard disk and the second is for a memory card. I expect you are using the wrong one..I was!
Dear Kishor Soni,
Your camera doesn't get information from terminal C of battery, thats why it gives such error message. Please check battery terminals at camera unit where you put/ install battery, aspecially C terminal. it can be rusty or dirty.
