After changing the filter the machine ask to clean with the tablet, right away I clean the capresso with the tablet, and state coffee ready, I turn it off and now says please wait
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
SOURCE: Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
SOURCE: Capresso C3000 Mega-weak coffee
I have a Capresso fo 7 years now, had few problems, but always solve them.
If youe machine does all the functions properly, but doesn't give you coffee, you should check if everytnhig goes into the grounds tray. If that's the case you may only have a broken "O ring" inside the pressing element. It makes the coffe, but throws it away instead of filling the cup. I had that problem, and it was the "O ring".
If the grounds dunped on the tray are dry, you're looosing the water in the back, probably on the relief valve.
Hope this helps!
SOURCE: Problem for Jura Capresso C1000 Espresso &
save a bundle, URNEX makes cafiza tablets, buy them by the 60 tabs or larger containers. Use them frequently and give some to friends. I've used them for years. find them online.
Please dont forget to vote this answer was helpful
Many thanks
