25 above ground pool smooth bottom water is right no algae, 1hp pump 13" sand filter
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: what is the normal psi on a haward sand filter
i was told that between 9 to 12 psi is normal on all pool pumps.
SOURCE: cloudy brown dirt getting in my pool from sand pump
The dirt you are getting is most likely from the air, dirt and dust present in rainwater and the small amounts present on human bodies. It is settling out and going to the bottom. I recomend a vacuum attachment that connects to your pump/filter to keep this cleaned out. Basically it "plugs In" to the outlet on the pool and will get all that out for you.
SOURCE: SAND IN ABOVE GROUND POOL
First, the vacuum should easily pick up sand if the pump is working properly. The sand in pool may be coming through a cracked or broken lateral. If you changed the sand recently and did not prefill the tank with water, then this could be the reason. Plastic parts do fail eventually. Be sure that you perform the rinse cycle aftewr backwashing to settle the sand bed. Instructions on filter tank.
Testimonial: "this would have been more helpful if i knew what a lateral was. we did not recently change the sand. we cleaned and used the sand from last season. "
SOURCE: I changed my sand in the filter last month, when I
If the water is beginning to clear up, it doesn't sound like you have done anything wrong. You might just need to let your pool filter keep working. I would
a) make sure that your pH, chlorine, and alkalinity levels are correct. An inproper balance of chemicals might be causing the cloudyness.
b) Be sure Vari-Flo valve is set on “Filter” position.
c) Operate filter for longer periods.
d) Make sure that the flow rate through filter is sufficient.
e) Continue to backwash frequently.
Try this for a few days and let us know if you still don't notice a change.
