SOURCE: Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
SOURCE: door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
SOURCE: kenmore elite front loader washing machine
has the fuse blown, if so replace this to ge the machine up and working to start with, set to drain only if you have the option, if the machine empties then the door may open, if its set to spin and the electric trips then there is a motor fault,, not much information given but now you have somewhere to start from
SOURCE: washing machine - door problem
it sounds like door mechanisim has fallen off.remove the top of washer/dryer and look down the front to where the door catch shuts and see if there is anything attached to it.if not your have to reconnect it.Let me know and ill give ya more details
