SOURCE: Message waiting indicator light is on but there are no messages
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
SOURCE: message waiting led stays on even though there are
Good Luck.
Whenever
this warning light or any other stays on in the dash it is indicating
that the systems control module (or the system sensor in the case of
lights like low oil pressure, door open indicators etc.) has detected
a fault, it then disables the system (this applies to ABS,TCS, TCM,
SRS, TPMS and BCM faults and others) as long as the light is on. You
must now have the dealer hook up a special electronic diagnostic tool
and "scan" the system for the fault code that is stored for
the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System
