Kenmore Side by Side Refrigerator Logo
Loren Foote Posted on Jun 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the mormal temperature swing of a Refrigerator?
My Kenmore side by side refrigerator has a freezer temperature swing between -10 and +10 degrees and my refrigerator side has a temperature of +32 to +45 degrees. This is my second refrigerator. The first one had even worse temperature swings and after several parts changes they replaced the refrigerator. Occasionally the food in the refrigerator will freeze. The first refrigerator was about 8 months old when sears replaced it and the new one has a manufacture date of 03/2014. My old refrigerator had an internal thermometer and showed 0 degrees in the freezer and 37 degrees in the refrigerator all the time with almost no temperature swing. After I had a couple of freeze events for this refrigerator I purchased a wireless thermometer to monitor both sides. I noticed when the refrigerator gets to 34 degrees on the thermometer things start to freeze. I have tried adjusting the temperature control but still get wild temperature swings. Sometimes too hot +50 degrees. UPDATE: I found out that if any food is close to the temperature sensor the temperature goes wild. So now I keep everything about 3" from the sensor from the front to the back of the refrigerator.
Harrie
Level 3:
Top Expert:
  • Kenmore Master 6,746 Answers
  • Posted on Jun 11, 2014
 Harrie
Kenmore Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1284366
Points
83153
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
  • Elie Balas Jun 14, 2014
    Refrigerator temp operating Range is 35-38 degrees. This is above freezing and below "life" temperature.
    freezer temperature should always be below 10 degrees and like stated by the master tech, should have very low variant of less then 5 degrees. Best way to test actual ref temperature is to inset the Thermometer probe into a glass of water, that will tell you the true temperature of the fridge.
2answers
Where is the temperature control located for kenmore coldspot refrigerator model 106.51139210
There are two temperature sensors (one in the refrigerator and one in the freezer). The refrigerator sensor is near the front of the compartment on the right side below the door switch and above the slides for the drawers. The freezer's refrigerator temperature sensor is on the left near the top of the compartment. See the two liner diagrams on the page linked below. To change the temperature, press and hold the Temperature button on the LCD panel for 3 seconds. The display should read the current temperature set point and Refrigerator. Use the Acceler-Ice button to lower the temperature in the fridge. Press the Lock button to raise the temperature in the refrigerator compartment. Press Temperature again to see the Freezer set-point and adjust it as above. Note: the temperature in each part of the unit depends on air circulating from the freezer into the refrigerator. Make sure that the vents aren't blocked. Wait 24 hours after adjusting the temperature set points for the unit to reach equilibrium before deciding if the set point should be adjusted further.
Sears Parts Direct has the parts diagrams for the 106.51139210 here: https://www.searspartsdirect.com/model/4lfq9qfxpx-000582/kenmore-10651139210-side-by-side-refrigerator-parts . This page also has a link to the owner's manual for the side-by-side refrigerator, https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1302214L.pdf . See page 15 of the manual for the information on setting the temperature set-points.
I hope this helps.
KITCHENAID SIDE BY SIDE REFRIGERATOR FREEZER DOES NOT FREEZE LIKE IT SHOULD BE. STILL WILL MAKE FEW ICE FROM THE ICEMAKER BUT DOES NOT FREEZE LIKE IT SHOULD BE, REFRIGERATOR IS AT ITS MAX TEMPERATURE WHEN...
Clean condenser coils, remove anything around refrigerator that might prevent air flow on coils. Make sure freezer and fresh food area door are completely closed.
Freezer is at -10, Refrigerator is at 52. hat is causing this? Model 106.53562202
check and see if there is anything blocking the side to side vents in inner wall- small1x1 vents,also ,anything hanging past edge of selves in fridge side causes air not to move around like it should - can cause drastic temperature swings
I have a 10 year old Kenmore Elite side-by-side refrigerator that is not cooling or keeping the freezer at the required temperature. I'm fairly handy and wanted to get help on trouble shooting the needed...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3helpful
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
2answers
Kenmore freezer keeps opening
tweak the hing locations on the freezer side to make it swing closed. sounds like it is tweaked to the other way.
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
1helpful
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
