Please check your needle position, putting it in backwards is a very common error, the FLAT side of the needle shank should be towards the back. Also be sure that during the transition, that the bobbin thread did not get misaligned.
So, make sure the needle has the flat side to the back, and rethread your bobbin thread through making sure it is correct.
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
