Check if you have one of the front tires out of balance . That is the most common issue . Did you lose a weight of one of the wheel from when it was balanced when installed . Check to see if you can see a spot where a weight was once located . did you hit a curb lately or pot hole. this alone would dent the rim and you would not know t until you really check if the tires are balance of the tires . Check that and if that does not work we will move on to the next thing to check. there is no sense just say all things it could be you start at the most obvious .
SOURCE: how do u replace a shifter cable for a 1988 honda accord lx
remove cable from transmission,follow cable behind engine,along exhaust pipe,then up through floor into center console.along the way you will find retainer clips (on both ends of cable) which hold the cables in place,and also underneath you will find a fastner which holds cable to bottom of floorboards and a panel with a rubber gasket in which the cable goes up into the console through. you must then remove center console to release the other end of cable.Once cable is loose go under car in the middle of the cable and pull out from floor then pull the other end out from engine compartment.
SOURCE: vaccum line diagram for a 1988 honda accord
http://www.pauldesign.ru/honda/shopmanual/62se320.pdf
There is a Vaccum diagram in that manuel.
make sure you are looking at the correct engine diagram
You mostlikely have the A20A3 or A4 that is the diagrams you should be looking at.
Good luck.
SOURCE: 1988 honda accord 2 door I need to change clutch
no remove gearbox but you might need to lower subframe to gain access ,use an engine lift to support gearbox or a block and tackle so you can pull it out and not have to lower it
SOURCE: 1988 Honda won't start
Cycle key to on, not start, and see if you hear fuel pump "humming". What engine, and is this vehicle carburetor or fuel injected?
SOURCE: 1989 honda accord 4 dr--new battery--starter will not start
make sure your getting full contact with you main positive and ground if nor another thing can be you fuel pump you can try replacing that also
