Dell PowerEdge 1800 Server Logo
A
Anonymous Posted on Jun 11, 2014
Poweredge 1800 power suply alarm orange
Not funcional server
German Cordero Rodriguez
Level 1:
New Friend:
  • Contributor 46 Answers
  • Posted on Jul 26, 2014
Contributor
Level 1:
New Friend:
Answers
46
Questions
0
Helped
9333
Points
97
Replace power supply
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 17, 2008
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
dmoufarrege
  • Posted on Jan 22, 2009
SOURCE: Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Anonymous
  • 148 Answers
  • Posted on Feb 26, 2009
SOURCE: Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Anonymous
  • Posted on Jun 11, 2009
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Shawn DuRee
  • 356 Answers
  • Posted on Jun 07, 2010
SOURCE: No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
2answers
Why does my dell mp1800 power and lamp flash orange
the battery needs charging. it is charging when it is solid orange and green when it is fully charged
I have problem in server dell poweredge 1900 it is orange light and wright error E171F PCIE fatal D4 F0 B0
Hi
Don't have a Dell, but the link below appears to give a solution that some people have found works for them
http://pcrepairpro10.com/dell-e171f-pcie-fatal-err-b0-d4-f0.php
May be worth trying.
Good luck
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
PE1800 server didn't start up at all, no green light in Power supply
Check and see that the power suply cables are properly connected to the power supply and that there is voltage on the Mains. If this is okay, replace the power supply unit.
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
1helpful
Orange lamp is blinking..
The fault was either likely faulty Power Supply or less likely Motherboard issue.
Or
A bad power supply... Just because you have some fans and lights working, this doesn't mean that the power supply is good
Problems connecting to the internet
unplug from power all things then plug back in,in this orderthe modem,then in 2 minutes,the computer,it should reset
Power
Most likey the PSU is dead, or fuse on the plug socket.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
