The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven.
To locate the thermal fuse, follow these steps:
Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician.
The thermal fuse in your GE Trivection JT930SOH1 oven is likely located behind the touch screen control panel. In order to access the thermal fuse, you will likely need to remove the control panel.
Before attempting to access or repair the thermal fuse, it's important to ensure that the oven is unplugged and that you have taken proper safety precautions, such as wearing gloves and eye protection.
Instructions to access the thermal fuse may vary depending on the specific model of your oven, so it's recommended to check the owner's manual for your oven or contact GE for instructions.
However, in general, you may be able to access the thermal fuse by first removing the control knobs and screws that secure the control panel in place. Then, you'll likely be able to lift the control panel off of the oven to access the thermal fuse.
It's important to note that the thermal fuse is a safety device, and it's designed to blow if the oven overheats. If the thermal fuse is blown, it will need to be replaced. If the fuse is not blown and the touch screen is still not lighting up, it could be a problem with the touch screen itself or a problem with the wiring or other electrical components of the oven.
It's recommended to contact a certified technician to diagnose and fix the problem.
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch. Thanks
I had the same problem. Had GE out, they said it might be something but they'd have to take the cooktop off and it might be $300 or it might not. I unplugged it and now use matches.
HI, This will be a simple fix here. The light switch will be the culprit. The circuit is damaged, thus, allowing for a continuously closed circuit. Simply replacing the switch will solve this issue. The switch should be mounted on the control panel. remove the control panel front trim screws, to access the switch housing.
