No. All of the significant landing sites can be seen from Earth by high powered telescopes. Astronomy and amateur telescope sites all have references and guides on how to find them and what times of the year are optimal for viewing them.
How to See All Six Apollo Moon Landing Sites Sky Telescope
its all about relative motion and being part of the earth atmosphere system, the plane is matched in speed with the earth. its the same reason we dont fly away when we jump up.
Can\'t see any specifics here, but in general: Pour a little boiling water over the battery terminals to clear the stuff, then remove the connectors and wire brush to bright metal. Clean the connectors similarly and refit, smearing with petroleum jelly to protect. Follow the negative lead to the engine, and disconnect here and clean in a similar fashion.
If you mean a component earth problem, easiest way is to make a temporary earth wire for the component which connects directly to the battery negative terminal. If the problem is resolved, clean up the component\'s earth path or simply install a permanent bypass earth.
hi steve my name is dalip i was reading your problem, i think you have only electrical earthing problem check all earthing. you have not written whether you have diesel or petrol version if petrol check distributor and wires attached to engine (1) engine & body-earth wire, (2) all earth wires like back-light, dashboard-meter, (3) AC relay wires (4) may be alternator, self earthing problem, my email [email protected]
There is a bad earth on the instrument cluster wiring.Unplug the main electrical connector on the back of the cluster and test all black wires for resistance to earth.The earth wire to this plug goes to an earth header behind the facia panel next to the accelerator pedal (right hand drive )or the clutch pedal (left hand drive).The resistance should be minimal.
