How do I
SOURCE: Operator voice mail
Your programming is off by one hour. Check the system clock and make sure it is on local time. Some systems require a manual reset back and forth for daylight savings.If the clock wasn't corrected, this will account for the voice mail redirect. Thank You. Jerry
SOURCE: ringer
If you are using Call Frwd No Answer use code # 603 or if you are using Call Frwd Busy/NAns use # 604 in the following set up.
Press " Intercom/ PDN " plus above code ( #603 OR #604 )
Enter Destination ( Usually Voicemail Access Code )
Press " Speed Dial "
Enter time delay ( 08 - 60 sec )
Press " Redial "
Time delay is default at 12 sec ( 4 ring cycles )
SOURCE: DKT 2020 ST
The phone needs to be fowarded to voice mail. go to the phone press intercom# 604, dial the voice mail extension number , press the speed dial button, enter 16 for time then press redial
SOURCE: Extending number of rings before voice mail engages
Is the caller being transfered to the ext or is it on incoming calls?
Tony
SOURCE: how to reset the voice mail password for toshiba
Log into mail box 999 and use sec code 999997 or just 997 and press 8 for admin functions. you might want to read the admin Guide
