Question about Casio Privia PX-350 Digital Piano Black 886830767784
What is causing noises in my Casio privia Digital piano?
My dp started to have mechanical noises only in some keys. The keys affected seem wobbly or slightly loose and seem to hit something. Only tapping the key repeatedly also seems noisy in such keys but it does not seem to touch the adjacent keys. So putting the finger on the key and move it sideways without pressing makes a noise so this can also be heard when playing and pressing the key down. Thank you very much
    Champion:
  • Casio Expert
  • 411 Answers
Pivots worn out or need lubricant. Make a warranty claim first.Otherwise, If out of warranty I would try to lubricate the hammer pivots myself. You will need "grease suitable for plastics".
Posted on Aug 02, 2014
3 Suggested Answers
SOURCE:
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
  • 3698 Answers
SOURCE: What is causing noise in the keys of privia px350?
Try using a can of pressurized air to clean around the keys that are noisy.
Posted on Jun 10, 2014
How do I remove the cover to fix a popped-up key?
Fixing the keys on digital piano. try to watch the video maybe there is a tips to fix your piano. thanks
Dec 26, 2015 | Casio Privia PX150 Digital Piano
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
Casio privia px350. My dp started to have mechanical stronger noises when pressing down the keys affected seem wobbly and seem to hit something as if moving sideways slightly. Only tapping the key...
The Previa key construction was a lot better than yamaha\'s, however it still suffered the normal casualties caused by even the slightest \'knock\'. Believe it or not, most damages are caused to DPs when you\'re NOT playing it. For example, transporting - setting up - packing down etc. I used to market Roland and Casio DPs for a number of years. And the most common problem was the \'stuck key\' syndrome (as well as dust on the contacts). I bought it down to the way people, children, adults actually SIT down to the piano to play. Instead of using the piano stool to balance themselves, many people place their hands on the KEYBOARD before they plant !!! NO NO NO :/ That is the prime reason there are key breakages in - pretty much the same place. Children are a classic example when they sit at a piano. They use the keyboard to leverage themselves UP. Because the DP is not on, it doesn\'t make a sound - therefore "it can\'t POSSIBLY my child\'s fault!!" Oh yeah...have your darling angel sit at an acoustic piano and they\'ll be playing 12th Street Rag before they even get their on the seat!!!
Long and short, possibly broken band, slipped hammer - or broken. Here\'s a video which explains how you might be able to fix the problem yourself. Not much to it really...just take your time and don\'t force anything
https://www.youtube.com/watch?v=_uToVbDDVC0
Regards
Sam
Jun 10, 2014 | Music
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How to reset the Privia Px-110 back to factory setting
Try this
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Casio Privia PX-350 Digital Piano Black 886830767784 Logo
148 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
