This is from the Power Gear manual. Probably a similar procedure.
AIR IN SYSTEM CHECK FOR COILS IN HOSE. REMOVE THE
COIL IF PRESENT THEN EXTEND ALL JACKS
TO FULL EXTENSION, THEN RETRACT FULLY,
REPEAT 4 CYCLES WAITING A FEW MINUTES
BETWEEN CYCLES, CHECK FLUID LEVEL IN
BETWEEN CYCLES
The DKT 2020 was used what a few different Toshiba systems. Users guides were referenced to the model and version of the systen rather than the model of the telephone. With that in mind, here's a link for a DK280 system, Most of the features should work ok.
The wep key is set by the system admin when the router is installed, contact the systen admin to get the wep key.
If you forgot it you have to reset it but logging into the router's setup through a browser by typing its IP address, then going to Wireless Network Security and changing the WEP key.
