My RCA DVD-R is STUCK ON "HELLO". I have unplugged the unit to
no avail. I have totally disconected the unit and it still is stuck.
Prior to this, the unit would stop in the middle of recording, At times
the time would change for no reason.
SOURCE: RCA DRC8030N Problem
hey maybe you can try this first before the other solution posted i just read..
Open it up and unjack the drive unit from the maid board. it hould be connected via a cable.. turn the unit on and it should display an error message or error code.. Once this is done unplug the unit and reconnect the cable this should reset the unit and it should work..
I have never tried anoter drive before in any unit cause i could never get it to work, i always purchased the exact replacement parts.. In your case i believe its cause the main controller is damaged or frozen.. If you got a battery n the board remove it wiat a few minutes and replace it this should reset the unit..
SOURCE: RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. [email protected]
SOURCE: Larger Hard Drive in DRC8030N
Yes you can replace the hard drive with a larger one. I have a 500 gig hard drive in mine. You can do the same thing with the DVD drive.
Any more problems, contact me at [email protected]
