Roper REX4634KQ Electric Dryer Logo
A
Anonymous Posted on Jun 10, 2014
Thermal cutout switch - Roper REX4634KQ Electric Dryer
1helpful
Electric tankless water heater light off, water hot
You will need a clamp on amp meter to check current draw. the thermal cutout tripped because the temp exceeded the safety limit.
3helpful
Espresso machine will not heat
on top of the boiler one cable is clipped tightly to the top under a piece of clear plastic tube.This is a thermal cutout in case of over heating,all power comes through this. Check both ends of this cable with a meter to see if there is con tinuity. If not the thermal cutout has blown and needs to be replaced. I believe this item is difficult to source.
A Carrier mod # 24ANA760A300 Infinity with an error code #72 high stage thermal cutout, What causes this?
if it's a thermal cutout that's mounted on the circuit board you may have to replace the whole board. I don't have the carrier error codes at hand. But a "thermal cutout" is normally found on the compressor. One advantage of the old (before digital) systems is that the controls were all separate. So you could replace a bad high pressure switch or contactor. Without having to replace a expensive circuit board that held most of the controls.
Not to mention being easy to damage by power surges and lightning
My cuisinart brew central, 8 yrs old and still going strong - until now, just turns off after brewing 1/2 pot of coffee. I can turn it back on easily by hitting the toggle swithch. Just started to do...
Hi, Eight years is unreal. I was going to suggest that the boiler elelment i s starting to fail, but i think it could be a thermal cut out which is positioned on the boiler. Thermal cutouts are connected to the main toggel switch. The thermal cutout turns of the power when activated. You can check it wity a meter (approx 12kOmhs). Id replace the thermal cut out anyway. They do ware out.
Hotpoint tdl30p thermal cutout required-no heater element working but heater element is fine when cutout is temporarily bridged-need part nr of cutout
Usually, there are 2 or 3 thremal cutouts in these machines (Side by side).
They should be changed together. I'm not sure if THT1001 is a hotpoint part number.
If you're in the UK, then go look at:
http://www.tdspares.co.uk/products.asp?cat=68 where you will get the pair for £8.95
My searches get drowned by UK entries because that's where I am!) If you're in the US, just google "hotpoint tumble thermal cutout" and you'll find loads (Note that proces vary hugely from $10 a pair to about $25!)
Jun 30, 2011 • Dryers
1helpful
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
1helpful
Microwave shuts off after 10 to 15 secs and does not heat up. Would the inverter or magnatron be faulty?
The following List of things would cause that, you can test each one till you find it or drop it at a service center...
-oven fuse
-thermal cutout
-door interlock switch or monitor switch
-thermal cutout
-fan jammed or faulty
-diode
-circuit board, triac or magnetron
let me lnow if you want any further instructions...
~chuck : testamonials appreciated!!!
Will be using my dc07 for about 10 mins then it cuts out i leave it to cool then it goes for about 5 mins and carries on like this
There is a thermal cutout on the motor causing this problem because it is overheating. Either it needs the filter replacing and a good blowout with compressed air or the thermal switch is faulty. Try replacing the filters first and if the problem persists it is probably a faulty thermal cutout. Dyson can either replace under warranty or an engineer will call and do a home refurb for a fixed price of £60
Spare parts
the thermal cutout is the thermostats u have two in a dryer one for the low heat and one for the high heat there just called a thermal cutout switch because it prevents the dryer from over-heating and setting a fire m8 but before you buy one just check if your thermostat for the lower heat might have a small reset button attached to it if it does then press this and if it not faulty will reset itself to start heating up again its that one with the reset buton that are called a thermal cut-out switch let me know which country you live in and i should be able to find you the cheapest web site to order from m8
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
