Hello pete, You may remember selling a Korg Pa 800 keyboard last year september, if not just to let you know I am the guy that purchased it. Recently my screen has had a problem. It is very dark not like usual when i turn it on. After 5 minutes it goes back to normal for 2 seconds and then goes dark and then this rythym continues like a light bulb being switched off and on. However the system works fine all the sounds and styles. Can you give me any advice on why this may be happening? Do you any where in the middlands where I can get this repaired or dealt with. Thanks
SOURCE: Hi I have a problem with RAM memory korg pa 800 in
If it says there is a RAM memory error, there is likely a bad module. If you installed these yourself, it is likely you have installed the wrong type or an incompatible configuration of the modules.
USUALLY the modules need to be identical in these synths. When upgrading, buy a complete set fot the unit and ones that are specifically guaranteed for it.
SOURCE: KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
SOURCE: Hello i have a korg pa 800 just a while ago
If this is not a low power supply problem, you might try circuit cooler to isolate the bad part.
Beyond the power supply I would recommend taking this to a shop for repair ONCE you have tried a factory reset.
Use this site for downloads:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
SOURCE: hi i im trying to
Your answer is here:http://www.korgpa.com/pa_root/en/products/pa800_soft.html Look under Utilities.
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
