UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
This just happened to me... the remote stopped operating the TV. Using the touch buttons on the front of the TV I deleted and re-registered the remote. All OK
How to Program the RMT-B107A Remote Control:
Follow these steps to program the remote control to operate a television.
1) Turn on the TV. 2) On the remote control, press and hold the TV I/O button. 3) While holding the TV I/O button, enter the manufacturer's code using the numeric buttons.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
4) Release the TV I/O button. 5) Point the remote control at the TV. 6) Press the TV I/O button to verify operation. NOTES:
If a new code number is entered, the code number previously entered will be erased. When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries. The operation of a combination deck of any kind is not guaranteed. Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component. In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control. ************************************************************
I contacted sony support centre to ask for code for sony RM-VL600T remote control, this is their reply below
I'm sorry, but there are no codes for the ASTVD LCD TV DVD COMBO. However, in some rare cases, you may not be able to operate your non-Sony equipment with the supplied Remote Commander. This is because your equipment may use a code that is not provided with this Remote Commander. In this case, please use the equipment's own remote control unit.
Thank you for understanding.
The Sony Email Response Team C6EM Brian
i have since learned the problem is that acoustic soultions tv are made for argos stores and are branded with their own name, therefore the modle is not registered as a tv brand to be used with universal remotes.
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
this how a dealer does it:
DOOR CONTROL TRANSMITTER
REGISTRATION
1. REGISTRATION OF RECOGNITION CODE
HINT:
The add mode is used to retain the already registered codes while registering a new recognition code.
This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously
registered code will be correspondingly erased in order, starting from the first registered code.
The rewrite mode is used to erase all the previously registered codes and register only new recognition
codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function.
Use this mode when the transmitter is lost.
The confirmation mode is to confirm how many recognition codes have already been registered before
an additional registration of a recognition code.
All the following registration procedures must be performed in order continuously.
(a) The vehicle should be in the following conditions.
(1) The key is not inserted in the ignition key cylinder.
(2) Driver’s door is OPENED. (The other doors are CLOSED)
(3) Driver’s door is UNLOCKED.
(b) Perform the following operations to select the desired mode.
(1) Insert and remove the key from the ignition switch twice within 5 seconds.
(2) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
key into the ignition key cylinder and remove it.
(3) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
key into the ignition key cylinder and close the door.
(4) Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1
to 5 times to select a mode.(2 times for rewrite mode) Then remove the key from the ignition key cylinder.
(5) After selecting a mode, the integration relay automatically performs the power door
LOCK-UNLOCK operation within 3 seconds to inform the selected mode.
(c) Register the new recognition codes :
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and
UNLOCK switches on the transmitter switch simultaneously for 1.0 - 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0
seconds.
(2) Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation
will be automatically performed once if the registration of the recognition code of the transmitter is
completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of
recognition code has failed. Perform the registration procedure from the beginning once again.
(3) If the multiple transmitter to be registered, repeat step (c) within 40 seconds after the previous registration.
this is why the dealer charges for this
