Question about Fisher and Paykel WA37T26G Top Load Washer
How do i remove spinner on fisher paykel wa37t26g
SOURCE:
SOURCE: Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Posted on Jul 27, 2008
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 389 Answers
SOURCE: Replace the console on a Fisher & Paykel GWL11
i am here to help if you get stuck good luck
Posted on Dec 03, 2011
walesarumi
  • 6993 Answers
SOURCE: my machine WA37T26G Fisher & Paykel has no power, it will not turn on.
Hello, welcome to Fixya!
The unit not powering on is an indication that it has a power fault.
First, remove the machine's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the machine, it goes straight into the power supply board which then circulates the current into the unit. So if the machine doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This machine must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the machine turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within our vicinity.You might also find visible bad component without testing with a meter. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Jan 04, 2012
fixya167
  • 122 Answers
SOURCE: Fisher Paykel WA37T26G doesn't spin as fast as should in rince and spin cycle
check motor brushes, or binding brake, centrifugal clutch Re: Jeff
Posted on Apr 12, 2012
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher-paykel washer fills on final spin cycle
Does your machine have a diverter valve,
If it does the valve is stuck in recirculate mode.
Lint has jammed it closed.
Feb 07, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Hi, I have a fisher and paykel washing machine model #WA37T26G and I noticed yesterday and today that the lights lit on the electronic board was 1,6,7,8...not sure if it was the same yesterday and not sure...
to work out the fault code go from right to left far right light is 1 the next is 2 next is 4 then 8, then 16,32,64,128. add up which lights correspond to your machine and then you can google that code and find what your problem is
Aug 19, 2017 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't spin, keeps giving unbalanced alert
You probably have a faulty Out of Balance Switch.This is a little micro switch inside the control box underneath the main computer module,right hand side.You will need to remove the modle to get to it.
May 31, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Apr 20, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel WA37T26G Top Load Washer Logo
80 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
