SOURCE: hi.... i hav 2gb kingston n it does not b format
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: i`ve just formated usb memory disk and lost all drivers
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the
whole USB flash disk surface will be fully erased.
Therefore, data
restoration will be impossible after using this utility!)
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
SOURCE: my 8gb kingston usb falsh
no need to worry friend first you need to active the usb port and then fix the pendrive to usb
follow bellow steps
---> ctrl+R
----> in this tyoe " cmd "
-----> in command prompt type usb drive name
examle : if drve is H then type like H:/ or F:/ etc
----> format H: or format F:
-----> if any question ask then u aswer yes press "Y"
----.> your problem is solve
in case failure then you can try this another operating system or another computer
SOURCE: my kingston 8gb flash drive shows 0bytes
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guide
how to recover files from USB drive
You may check out this video tutorial also
