I have songs on my mp3 that when I play back the sound goes from loud to unhearable. I am thinking the input level must have been different. is there a software that would correct this problem? I ride my Harley and I cannot hear some of the songs I have recorded Thank you for your time Kevin
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
SOURCE: Rca H106A 6GB player
Sometimes all you need to do for that is profile the songs. This organizes the songs into the correct catagories.
SOURCE: Philips GoGear mp3
Sounds like the files are DRM copy protected.
You can check for protected tracks.
The HDD1830 is not compatible with protected files, although your PC will play them ok.
SOURCE: mp3 player plays back songs too fast
First step is trying to do a firmware upgrade from RCA.COM. Go to the support page and look for your Lyra by model. Let us know if this corrects the problem.
SOURCE: sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
SOURCE: Mp3 plays few seconds of song.
Do you mean it plays a few seconds then skips onto the next song? If that is the case then most likely you have "Intro" play set which only plays a few seconds as a introduction then skips to the next time.
To fix this, during music playback, press the [menu] button, then there should be an option there to change it from "Intro" to "NORMAL" instead.
Hope that helps.
