SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
SOURCE: the heater plate on cuisinart cbc-1600 coffee
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
