4 beeps every 2 minutes has 2 causes:
1) LOW oil level in the engine mounted reserve tank ( fill it up manually )
2) Water in the engine mounted water separator/fuel filter ( clean out )
This could be a lot of things. Have a computer scan done to see what the issue is. Could be a bad poppet or water pump. There is a sensor in the oil tank that can cause this too. Also the throttle sensor.
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Once the fuel and oil are mixed, there is a problem with the seal of the generator set, which happens from time to time in use. It might indicates that the seal of the generator is out of order. Or it can be caused by excessive cleareance between piston and cylinder.
1. Pump membrane rot or degumming, so that diesel oil into the oil tank and oil mixing.
2. The injector has low opening pressure and poor atomization, which causes diesel oil to flow into the oil pan and oil along the cylinder wall.
3. The oil seal of the front end of the fuel injection pump is invalid, and the check hole cover of the gear chamber cover is removed.
