Kodak i660 Scanner Logo
Simon Grech Posted on Jun 10, 2014
Anyone knows where I can get a service and parts manual for the Kodak i600 series? Does anyone know what Error id=009 means and how to remedy it?
I tested the scanner on my laptop for a continuous hour without fail. I put it back on the pc and after 40 minutes it fails with this and other error numbers (not got them to hand). However when I connect a i640 scanner on the same PC (card/cable etc) it runs without errors. Also the i660 was running on same PC before. Just started. Thank you.
carole liasi
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jun 12, 2014
carole liasi
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
9046
Points
65
Downloadable versions here
http://www.kodak.com/ek/US/en/Home.htm
2answers
What does Err4 mean on proline PFL510W-U1 washing machine
proline pfl510w u Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > proline pfl510w u
Washing Machines proline pfl510w u questions and answers. ... need user manualfor proline logic on line need user manual for proline logic ... PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and ...
Washing machine PROLINE PFL510W - Manual.com
https://www.u-manual.com/...manual.../washing-machine-proline-pfl510...
On this page you can get: Washing machine PROLINE PFL510W manual - is available for free download. All information such as file size, preview picture, ...
Anyone know how to reset a Proline washing machine ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comApr 3, 2010 - I can't find the manual, either at home, or online. Our washing machine(PFL 1466W-U) is showing off today. We've managed to take ... Does anyone know how to stop it from running this programme, so that we can select the empty/spin cycle. We have .... Ok it's a cover not written but you know what I mean.
2answers
"call service " errors on a kodak i600 scanner, what are they and what do the numbers mean
All errors you can't solve, without replacing parts, will give an error call service centre.
In only a few cases, it only has to do with a bad connection, but it also can be a problem with components becoming to hot and switching off. Please follow the advice the machine is giving.
Too often people ask how they can put back together, some things they started "repairing" and could not work out how to.
just saying.
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
2answers
I reset my canon ip2770, but the error code is 009
So what does the error code allude to? Lens? software? Connections? Unless you know what the code stands for how you or anyone be expected to fix it?
Have a kodak c160 purchased at wallmart. can,t use it without instrucions. need to know what all the icons mean can not find any info on the kodak sites. can,t use it without user manual.is there anyone...
user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19071/kw/c160
extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19068/kw/c160
Error Message when printing
Hi there
This error I not think you will find on the hole internet I not seen this number error befor, this is a new error....
13helpful
3answers
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
