SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
SOURCE: Canon DR-2580C scanner - green light just blinks.
I have many years of experience with Canon scanners and I think I may be able to help you with your problem.
On that particular model of scanner there is a micro switch to verify the top half of the scanner is closed. On the top half of the scanner the part that flips up you should see a peice of plastic towards the front protruding downward I belive on the right hand side towards the front of the top half but on the side of it. If its not there then it has broken off, if you can find it you can glue it back on with super glue. If that peice is there then look straight down on the same side of the scanner that peice is on you will see a small opening and you may see a small peice of silver metal. That is where the micro switch sits and the plastic peice on the top activates that switch. If the switch doesnt get activated then the green light blinking problem will occur. To replace that switch or adjust it you will need to remove the covers from the scanner the back cover first with I belive has 5 screws in the back. There is a tab on the bottom of the scaner that needs to released so you can remove the side cover, you will see a square hole towards the front of the scanner on the bottom. Use a very small screw driver to push the tab in to release the cover. Take your time doing all this because you will need to reassemble the scanner once you make the repairs to the micro switch. If you have any other questions let me know and I hope this helps you out with your problem.
