Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
A
Anonymous Posted on Jun 10, 2014
Need minnkoda control board - Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
How can I solve SC 995 error for Ricoh Afcio 2027?
SC995 is a controller board not compatible error. You have replaced the controller board with the 2022 or 2032 board. All other boards and parts for this machines are the same. Only the controller board is different for all three models. But if you have not change the controller board and this SC995 appeared then the controller board is defective and need to be replaced.
1helpful
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
My garage door is not working is like not electricity
All you need is to use a multimeter to check the input voltage to the control board , ALso check the motor with a test to confirm the fault on the control board.
Only if you are tech savy can you be able to identify the faulty part as the control board circuit needs to be checked for the drive parameters.
If not get help to replace the control board or send it for repair to the dealer.
Code F- Won't spin
Hi, it means you have an internal short in the display control board. You'll need to order and replace the relay control board in order to correct the issue. This control board is located on the far right corner under the control panel. Below is a link to the control board you'll need to order and replace. Click HERE.....
2helpful
My maytag 3000 washer displays f70
Hi
Error code F70 means Control Unit Failure, no communication is detected between the control board & interface. You'll need to use a multimeter to check for the continuity between the Keypad and the control board. Inspect the wiring between the boards. Also check for any burnt component on the control board. You may need to replace the control board or user interface. To be sure whether the boards use a multimeter. Usually if the drum moves then user interface is bad else its the control board. hope this helps...
Daniel
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at [email protected],i need one.
The tub that holds the clothes does not spin. The water goes in and it takethe soap and softner but will not spin. The timer works and it seems to go through the cycles and fillls and emptys but the tub...
I've only seen one of these belts break in my 7 years of fixing Neptune's. I have replaced dozens of motor/ motor control board kits. Maytag upgraded the washer motors about 5 years ago, if yours is older it's probably got the older style motor. If that's the case you need to verify that the motor control board is getting power from the main control board, if it is, then you need to replace both the motor and motor control board (it comes as a kit). If it isn't you need to put 120 volts to the motor control board and see if the motor spins at 50 rpm (normal agitate speed), if it does, you just need the main control board, if it still doesn't run you need the main board and the motor/ motor control kit. If it has the newer motor, you would also need to test and replace the motor and/ or the motor control board separetly.
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
2answers
Frigidaire Washer - pressure sensor
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
